overwrite default output-Directory for datadownload service
  • Oct 9, 2018 1:53 PM UTC
  • 40 views
Hello
I need some help in configuring the directory, where my datadownload-service sends its zip-files to...
can this be done on the workbench-level?
Thanks!
Hi @broens,
I think this article describes what you are trying to do: https://knowledge.safe.com/articles/882/create-specific-directory-structure-in-the-data-do.html
It includes an example .fmwt and requires you to do two things at workbench-level before publishing the workspace back up to Server:
  1. Set up the FME_SERVER_DEST_DIR parameter
  2. Use the Fanout Dataset advanced parameter to specify the directory location
