Is it possible to publish a workspace to FME Server from the command line?
patlougheed
Forum|alt.badge.img+3
Hi folks,
I'm building a set of workspaces that are combining into a larger whole and will be running on FME Server. Given it's a number of different workspaces, I'd like to be able to publish to the Server from the command line - partly because I'm lazy, but mostly because I'd like to avoid getting versions out of sync between my local repository and what's on the Server.
It appears (based on text output) that the publishing process from FME Workbench uses a process behind the scenes, but I can't find any documentation about how to publish from the command line. Is this possible? If so, is there any documentation or can someone provide the appropriate command line magic to make this happen?
I know this could be accomplished with the API, as well, but I'm attempting to avoid writing anything new if I don't need to.
Any help much appreciated, and thanks in advance!
Pat
Be the first to reply!
