Invalid path in Network Directory Watch, but workspaces can access it
  • May 15, 2024 2:54 PM UTC
  • 298 views
mathiasboudreau
Forum|alt.badge.img+4
We have recently upgraded from FME Server 2020 to FME Flow 2024.
I have an Automation with a “Ressource or Network Directory (updated)” trigger watching a folder on the network. The automation was working before upgrading, but now it says “Invalid path to watch:”
What’s strange is that I created a workspace with a PATH reader pointing to the same network (UNC) path, and it’s able to read and log all the files in the folder I want to watch. I’ve also tried reading a file in that directory using a textfile reader, and it works.
I don’t understand why FME Flow can read the files in that directory on the network using a workspace, but the automation can’t. If you have any ideas/explanations or possible solutions.
The user account that runs the FME Flow Core service has read and write permission on that directory.
Thank you in advance
Best answer by mathiasboudreau
Thank you for your answer,
It’s now working, the problem was that the user account running the FME Flow Application Server service and the FME Flow Engines service had read/write permission on the network directory, but the user account running the FME Flow Core service didn’t have read/write permission on the network directory.
We’ve added the permission for the FME Flow Core service and now everything is working!
timatsafe
Forum|alt.badge.img+8
  • May 16, 2024 7:29 PM UTC
Hi @mathiasboudreau,
Have you tried deleting the Resource or Network Directory trigger and creating a new one? Could you send a screenshot of your automation trigger configurations?
-Tim
mathiasboudreau
  • May 16, 2024 8:29 PM UTC
