How does SystemCaller trigger a Failure in Automation?
  • Mar 31, 2023 2:14 AM UTC
  • 135 views
nicholas
Forum|alt.badge.img+14
I have an Automation on FME Server, which runs a workbench and that workbench runs a SystemCaller which runs a python script.
Occasionally, the python script fails to run, and I want this failure to be recognised by the Automation, so that it sends me an email stating that it has failed.
How do I do this?
I can see how to set up the SystemCaller so that the Output Exit Code Attribute has a value of nonzero (representing failure)
But how does this trigger the workbench to fail inside the Automation?
I need the Automation to recognise the failure event so that it can generate an email stating that.
nielsgerrits
Forum|alt.badge.img+67
I think you are looking for the Terminator?
nicholas
  • Nov 26, 2024 5:06 AM UTC
I solved this by adding a Tester just after the SystemCaller which tests the value of the Exit Code.
I then attach a Terminator (as per ​@nielsgerrits ) to the “Failed” output port of the Tester
Then in the Automation I attach an Email Action to the “Action Failed” port of the Run Workspace action
