Automation Parameters are Resetting
dellerbeck
If you have an existing automation and need to make a change, you make your changes and publish \\ overwrite in FME Forms. Once you go to the automation and stop it, all parameters are reset to defaults.
This happens even to workspaces that were not updated. This has happened the last 2 or 3 releases, currently we are on
FME Flow 2023.1
Build 23619 - win64
todd_davis
Forum|alt.badge.img+22
  • November 1, 2023
Yes, I have seen this happen as well. And I spent a lot of time trying to replicate it without being able to pinpoint the cause, although I could see that the front end did not make the api call to update the parameters. My case was "C684074 - Automation returning to default value" but without the ability to find the reason, it was hard to fix.
ctredinnick
Forum|alt.badge.img+18
  • November 1, 2023
There was a bug in FME 2019 where Choice (Multiple) parameters which had a space in them would not save in an Automation (the save button reset the parameters). It had to do with space being used as a delimiter for the multi-choice parameter, and funky use of "quotes" "around parameter" "names" in the automation. If you create a plain workspace with a simple text parameter, does it still get reset to defaults?
dellerbeck
  • November 1, 2023
I can actually reproduce my error pretty easily. It happens whenever I overwrite an existing workspace from Forms that is in an existing automation. I even changed to deployment parameters where I could and eventually had to set up defaults per parameter so it would not break if I made future changes.
dellerbeck
  • November 20, 2023
I think the issue was with the space in the parameter dropdown list. We have a Dev, Test and Prod environment, to make sure we see if we are in production we made the name GIS Gateway. I removed that option from all workspaces in 1 automation and am no longer able to reproduce the issue.
I have 3 more automations and probably 10 more workspace to go through. This should prove it this was the issue!
Thanks again everyone!
sigher
Forum|alt.badge.img+4
  • November 4, 2024
Still have this issue on certain workspaces / automations in FME 2023.1. 23619. It seems to be related to when the automation changes somehow. Difficult to debug, but the end result is that at next time the automation runs it has the default values and not the correct values.
It has happened several times on several workspaces the last months now, so we are trying to figure out what the issue is.
Any more update on this from Safe Software side?
cnieman
  • March 5, 2025
I had noticed this previously, but not for awhile until yesterday when I updated an automation “global.” parameter and all of the workspace parameters were reset to default so the automation no longer worked.  Nothing else changed - none of the workspaces were republished.  All I did was stop the automation, change the automation parameter and restart the automation.
FME Flow Hosted Build 24620.
Forum|alt.badge.img+32
  • March 10, 2025
I appear to have run into this issue today - Build 24612
sigher
  • April 3, 2025
Appeared again for us also. FME 2023.1. 23619.
sdepriest
Forum|alt.badge.img+9
  • April 14, 2025
We have experienced this with FME Flow 2024.2.3 Build 24825 - win64 just this week.  Prior version was FME Flow 2024.0 Build 24187 and we had it happen there also.
