Writing to Dutch Kadaster SFN format
  • Nov 28, 2016 8:05 AM UTC
  • 8 replies
  • 114 views
annette2
Forum|alt.badge.img+11
annette2
  • Nov 28, 2016 8:09 AM UTC
I've had a request internally to write data to SFN format. This is a format that the Dutch Kadaster delivers data to us in. The SFN format is required for a custom Smallworld importer.
Has anyone ever used FME to write this data format?
Thanks,
Annette
Forum|alt.badge.img+63
Thanks,
Annette
I've gotten quite a long way towards a working BGT-to-NEN1878 workspace a few years ago and if I'm not mistaken the SFN format is very similar to that. Feel free to contact me directly if you want to discuss this.
itay
Forum|alt.badge.img+19
  • Nov 28, 2016 9:46 AM UTC
Had my share of attempts with this format, not an easy task, so good luck @annette2 !
annette2
  • Nov 28, 2016 9:58 AM UTC
That's what I thought and wanted to check. I've seen some custom python code which didn't make it look like an easy task. This is a temporary solution during the switchover from GBKN to BGT so I'm not sure it is worth it. Dank jullie wel :) @redgeographics @itay
itay
  • Nov 28, 2016 10:00 AM UTC
Sure no problem, the SFN is a dying format, luckily!
jpdenboer
  • Dec 3, 2016 9:59 AM UTC
Beste annette, Giskit heeft een goedkope dgn/dwg to SFN converter. Is dat een tijdelijke oplossing?
helmoet
Forum|alt.badge.img+8
  • Mar 15, 2017 12:25 PM UTC
Dag @Annette2, SUFNEN wordt niet ondersteund door FME. Vicrea heeft een plugin voor FME die het formaat kan lezen (NENMOVER).
annette2
  • Mar 15, 2017 12:32 PM UTC
Dank je wel Helmoet. Henk sent me a copy of it in January.
