I want to submit a job to fme server at the end of a "published workbench".
Is there any way to achieve this?
I googled that it is possible through a python shutdown script. Can someone give any pointers for this approach.
Thanks
Thanks
that would depend somewhat on how the job in configured on FME Server, e.g. if it depends on data being uploaded, etc.
But if you just need to run a Workspace on your server with some parameters, you can do this using the REST API of FME Server. Example:
http://fmeserver.com/fmedatadownload/Samples/austinDownload.fmw?FORMAT_GENERIC=MAPINFO&opt_responseformat=json
This will trigger the Data Download service and give you the response as a JSON object. For more examples, visit the FME Server playground and the documentation.
As you can see, it is simply a URL that you send along. Using Python, it could be done like this:
import httplib import json conn = httplib.HTTPConnection("www.fmeserver.com") conn.request("GET", "/fmedatadownload/Samples/austinDownload.fmw?FORMAT_GENERIC=MAPINFO&opt_responseformat=json") resp = conn.getresponse() if resp.status == 200: data1 = resp.read() serverResponse = json.loads(data1) else: print "Error:", resp.reason conn.close()
You now have a dictionary object "serverResponse" that contains all the values returned by the FME Server workspace.
David
One more thing, i am also using a fmeJOBSubmitter Transformer inside my workbench to call another workbench on server.
This thing is working fine in FME Server 2012 but now we have to move our code to FMESERVER 2013.
In server 2013, the jobSubmitter transformer is not working as it should. I am getting error "myWorkbench.fme could not be opened" altough it is published in server and i am able to select the workbench in job submitter.
Is there and change in config for server 2013. Please help.
