Startup script that reads features in file
  • Jan 9, 2019 6:21 PM UTC
  • 50 views
Hello,
I am trying to develop a startup python script, that will look at an incoming file and list the feature types that are within that file. Then compare against another list of mandatory feature types. Essentially I would like to make sure that required feature types exist in the file. I am fairly new to Python, and still learning, but any guidance would be helpful.
import fmeobjects
import fme
class FMEFeature(object):
value = fme.macroValues['SourceDataset_AUTOCAD_OD']
fme.getFeatureType(value)
#unsure what to do next
Thank you!
itay
Forum|alt.badge.img+19
  • Jan 9, 2019 6:55 PM UTC
Hi @david_prosack88,
You could use the Schema (Any Format) reader to read the feature type from both files and compare, no python needed.
Hope this helps,
Itay
