Selection sequence via published parameters
  • Dec 21, 2018 3:18 PM UTC
  • 85 views
toth17
Hello, I have in front a reader SpatiaLite composed of different layers (hydrographic basins, communal limits, regional limits ... "). I want to propose to the end user a list of extraction options (list of watersheds, list of municipalities, list of regions ...) according to a type of previously selected right-of-way ("watersheds", " regions ", ...).
I arrive with a published parameter applied on a transform tester to select the type of footprint stored in the format attribute "fme_feature_type" and store it in a new field "Emprise" with the "conditional attribute values" in an AttributeManager.
But I do not succeed after to chain a selection on the selection via a second published parameter. The selection of the right of way is not filtered according to the first choice. Thank you in advance for all your advice.
Best answer by jdh
Unfortunately that is not currently possible.
If you would like to see it implemented please vote on the following idea:
https://knowledge.safe.com/content/idea/23140/ability-to-set-parameter-relationships.html
jdh
Forum|alt.badge.img+41
  • Dec 21, 2018 4:37 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • Dec 23, 2018 10:38 PM UTC
Nice. i voted now this Idea.
toth17
  • Dec 24, 2018 2:04 PM UTC
Thank you for answering my question and a pity that it is not possible at present even if it did not seem insurmountable as a procedure. I will vote for the idea. Thanks again
