Released
FME Server Web UI - Implement calendar selection for Date/Time parameters
Related products:FME Form
rylanatsafe
While using the Published Parameter type Date/Time in FME Workbench, a Prompt and Run offers the user an option to select the date via a calendar. When the same workspace is published to FME Server, this parameter is only configurable as a string in the format "yyyymmddhhmmss" in the Web UI.
It would create a better user experience if the FME Server Web UI implemented the option of calendar selection for the Date/Time parameters.
  • September 12, 2017
Does anyone know if this was implemented in FME Server 2017?
Thanks.
courtney_m
Forum|alt.badge.img+5
I actually had a client ask me about this last week! Any idea if this will be implemented soon?
rylanatsafe
Forum|alt.badge.img+13
@preichart - This is not currently in FME Server 2017.1.1 Beta Build 17638 nor FME Server 2018.0 Beta Build 18166.
This Idea will have its status change from "Suggested" to "In Beta" and ultimately "Completed" if development progresses. On the right-hand side of this page you can select Follow to receive email updates – given that your Knowledge Center preferences are set to send out notifications.
rylanatsafe
  • May 28, 2018
This feature is now available in FME Server 2018.0!
Please note the animation is captured from FME Server 2018.0.1 Win64 with Google Chrome on macOS.
