Scheduled task to run Workspace in FME Desktop
  • May 24, 2021 9:17 AM UTC
  • 106 views
simonhume
Forum|alt.badge.img+7
Hi
I'm trying to set-up a Scheduled task to run a workspace whilst i'm on leave
The Scheduled Task has been set up to look at a .bat file, copy of which is attached to this post
when i run the .bat file using the cmd prompt, i get the following error message;
File \\\\gis\\GIS\\ITDATA\\FME\\Batch runs\\Standard Runs\\StatMap_QGIS_Addr_Cross_Refs.fmw--SourceDataset_CSV2 could not be opened
Program Terminating
Could it be failing because there are 3 seperate csv files running in the Workspace?
I've copied SourceDataset_CSV2 to a local drive, as well as changing the file paths back to the mapped drive locations, but am still getting the error message
Has anyone got any advice or workarounf they can provide?
thanks
Simon Hume
caracadrian
Forum|alt.badge.img+23
  • May 24, 2021 10:58 AM UTC
Get rid of the wildcard characters (*) in SourceDataset_CSV2 filename.
simonhume
  • May 24, 2021 12:08 PM UTC
@caracadrian​
thanks for your reply
I've tried that and it's still failing
There are 3 csv files in the folder, so i've had to use a wildcard so it uses a specific file (which has a date in the filename, so changes daily)
I've also copied the specific file to a local drive and renamed it to the actual filename, but still get the error message
