Reclassification of attributes into groups
arnold_bijlsma
Forum|alt.badge.img+14
I have an address table where each address point is classified into 1 of about 500 classification codes. I need to reclassify / condense this into just 10 codes:
1 = Code R% = Residential
2 = Code C% = Commercial
3 = Code CE% = Educational
4 = Code CX% = Emergency Services
...etc.,
where % is a wildcard character
I have tried a couple of transformers, but most don't support wildcards, so the 'best' option so far I have come up with is 10 pairs of Tester+AttributeCreator transformers in sequence.
My feeling is that there may be an easier way. Is there?
(Note: I am aware of the overlap in codes. The second line classes all lines starting with C as Commercial, but then the third line reclassifies those starting with CE as Educational)
Best answer by fmelizard
Yes there is, one AttributeCreator in which you make use of the conditional values definition.
http://blog.safe.com/2013/03/fmeevangelist113/
fmelizard
Forum|alt.badge.img+19
  • August 19, 2015
arnold_bijlsma
Hi Itay
Dankjewel. That was exactly what I was looking for! See below for some screenshots. And also thanks to Mark Ireland for the very well and clear written blog post.
My AttributeCreator Condition Definition:
My workspace, showing Before in pink and After in green:
fmelizard
  • August 20, 2015
Graag gedaan, Its a great addition that I use very frequently wouldnt know what to do wothout it nowdays.
