Reading specific layer by user Param from a Geopackage.
  • Jul 6, 2020 3:49 PM UTC
  • 163 views
Firstly I'm fairly new to FME so this might be something so simple but I couldn't find anything.
My aim is to read a Geopackage (that may or many not have many layers) and grab a specific layer from that Geopackage that is defined by a user param and write it as a Geopacakage with the associated schema.
I started playing with the feature reader and using the Feature Reader with Feature types to read but the output port doesn't change after the first run through.
This has to be something simple I'm missing.
  • Jul 7, 2020 7:07 AM UTC
Could it be that you're wanting to use a dynamic schema?
https://knowledge.safe.com/articles/1050/dynamic-workflow-tutorial-introduction.html
The article uses regular readers and writers in the examples, but the principles hold for the FeatureReader as well.
  • Jul 8, 2020 9:45 AM UTC
So I'm not sure I've explained myself to well, I am expecting dynamic schemas as I am looking to pull specific layers from geopacakges these could be different geometry types, the sample data set I am working with has two point layers and one polygon. The layer to be request is a user param. I orginally did get this to work with a feature reader however now ive notice it only works on the first run. I'm attaching the workspace as it might make more sense update_delatas_vector_v0.2.fmw
