Hi, I am retrieving data through an API using an HTTP caller. The data consists of points and lines. My plan is to pull this data, perform some attribute mapping, and then POST it to a website. However, I'm having trouble extracting geometry after flattening the JSON data. I used a Geometry Replacer, but it fails every time I run it. The error message says:
INVALID_PARAMETER_GEOMETRY_SOURCE
I would appreciate any assistance with this!
