Preserving xattributes when writing DGN
  • Oct 14, 2016 9:56 AM UTC
  • 80 views
Hi!
As the topic tells, I'm wondering if it's possible to write dgn file with xattributes?
I have dgn file with building information in it as xattributes. Im trying to write it through fme back to dgn file with all the same features.
Just to see if its possible. And there is some projects where it might make my working bit faster.
Regards,
Aki
itay
Forum|alt.badge.img+19
  • Oct 14, 2016 10:07 AM UTC
Hi @a7, not sure its possible, I would try to generate a workspace and see if FME can recreate the xattributes (are those XFM reference elements you are referring to? or tags?)
  • Oct 14, 2016 10:26 AM UTC
Thank you @itay, for your intrest!
It's XFM reference elements.
I've tried some simple ways for it without any good results. Been looking all day through internet different uses for xattributes, but found suprisingly little.
itay
  • Oct 14, 2016 11:30 AM UTC
The only mention I can find about it is in the writer parameters where you can select to writer XFM reference elements from a seed file.
This naturally implies that you will need to use a seed file in your transformation.
