Path issues while attempting to load Python module
  • August 22, 2024
  • 5 replies
  • 132 views
jhawks
Forum|alt.badge.img+7
Path issues while attempting load Python module. FME Pip installed Pypdf. It got installed to:
C:\Users\james.hawks\Documents\FME\Plugins\Python\python39\pypdf
But workbench cant see that for unknown reasons.
Python Exception <ModuleNotFoundError>: No module named 'PyPDF'
bwn
Forum|alt.badge.img+26
  • August 22, 2024
Does not really address the problem/cause,  but a general workaround I’ve use is to copy/paste the PIP package files into the FMW folder.
FME seems to always search the FMW folder first for the called Python module, and so this works for me when mucking around with OS Environment Variables has failed otherwise.
jhawks
  • August 23, 2024
That’s only if the workbench is published correct? If not where is the FMW folder on Client?
bwn
  • August 23, 2024
Are you getting an error from a Workbench translation?  The FME Workspace file (FMW) folder location is output on the Translation Log
and in Workbench is part of the Application Window Header
jhawks
  • August 23, 2024
Workbench for now, will publish eventually. Placed pypdf in the workspace folder. Still no good.
jhawks
  • August 23, 2024
Wait cases matters! Matched it, onto the next error!
Python Exception <NameError>: name 'os' is not defined
Error executing string `
import PyPDF
