Wondering if there is a solution to this problem:
When using the 'Sequenced Table Columns' Format Parameter on the Oracle Writers (allows you to specify an Attribute and Sequence to populate that Attribute with the next value from the sequence) but I couldn't use it with a Fan Out. If all Feature Types used the same Sequence that would be OK. But if one Sequence per Feature Type I couldn't get it to work.
Any suggestions?
