Oracle db connection to FME
  • Jan 23, 2018 12:25 PM UTC
  • 21 replies
  • 1131 views
Hello,
I am trying to connect a Oracle DB to FME but even if I did everything from this link it is not working.
Does anybody have any idea what could be the problem?
  • Jan 23, 2018 12:32 PM UTC
What version of FME and is it 32 or 64 bit? You need to match the Oracle Client as 32 or 64 bit. It is possible to have both.
One thing I like to do is to use SQLPlus to check the connection to Oracle - If SQLPlus can't connect FME probably can't.
Wondering also if the Service name allows an IP - Is you TNS Names configured correctly - the suggestion above will prove that.
Also when you click the Test button it should return an error - what does it say as the reason for failure? You can also Show Log which you can paste here.
As it can be seen FME is x64 and also Instant Client is. I can access this data base from SQL developer and it is not a problem but I am trying to find a way how to write some results from FME to this base that already exists. I don't know what could be a problem in FME so it doesn't want to let me to connect db and FME.
  • Jan 23, 2018 12:40 PM UTC
Can you post the SQLDeveloper connection details? Is it using TNS or Basic connection?
  • Jan 23, 2018 12:43 PM UTC
It can't find your Oracle Client - did you use the Oracle Installer or a manual configuration?
  • Jan 23, 2018 12:45 PM UTC
OK I think the problem is in the Environment Variables.
The PATH variable needs the directory where the Oracle Client is installed. You do not need the InstantClient variable and certainly not pointing to oci.dll
Is my setting - yours will be in a different directory.
It is basic with SID but I don't get it why FME is not accepting it.
  • Jan 23, 2018 12:55 PM UTC
As posted above - from your original screen captures - it looks like the client isn't installed correctly.
@mark_1spatial Where can You see that? Which client is not installed correctly?
UniversalReader -- readSchema resulted in 0 schema features being returned Error connecting to Oracle database: message was `ORA-12514: TNS:listener does not currently know of service requested in connect descriptor'. (serverType=`ORACLE_NONSPATIAL', serverName=`147.91.175.146', userName=`DRAGICFME', password=`***', dbname=`')
Failed to read schema features from dataset '147.91.175.146' using the 'ORACLE_NONSPATIAL' reader
Now I get this error. I changed value as in Your picture.
  • Jan 23, 2018 1:10 PM UTC
Try setting up the connection like this image (EasyConnect) where the conenction details are all on one line:
See this link:
https://knowledge.safe.com/articles/827/connect-to-an-oracle-service-name-not-oracle-sid.html
This is because it seems TNS Names is not configured or readable.
Another good resource:
https://knowledge.safe.com/articles/28996/fme-and-oracle-troubleshooting-guide.html
See this link:
It is not working again. Damn.
log.txt
Here is log file but I have not idea what is problem and why it doesn't want to connect but this is really important for me.
@mark_1spatial
  • Jan 23, 2018 2:55 PM UTC
See this link:
@maliodpalube did you try the EasyConnect suggested above?
The problem looks like Oracle TNS Names configuration - which is not FME, but you can work around TNS using EasyConnect.
An explanation of TNS Names
http://www.orafaq.com/wiki/Tnsnames.ora
tibor
  • Jan 24, 2018 10:46 PM UTC
You're Oracle connection is missing an sid or servicename. This identifies the database instance that's is running on you're Oracle server. Out of the box Oracle uses orcl as the instance name. DBA's change this name to an name that's identifies the use of the database. On Oracle server can host multiple database connecting through different port numbers. Standard portnumber is 1521.
You're connection to oracle has only an IP address. That's not an valid connection.
When using TNSNames you give an Oracle connection an name (Alias). This cannot be an IP address. So I assume you are trying to connect to Oracle via an Easy Connect.
The richt syntax for Easy Connect is.
<servername or IP Address>:<portnr>/<service_name>
You can test if the Easy Connect is valid inside an command box (cmd.exe).
For example:
IP: 147.91.175.146
port: 1521
service_name: orcl
tnsping 147.91.176.146:1521/orcl
I think the connection will be woring in FME when you are using the bold text as mentioned above after TNSPING.
P.S.
You should consider not to mention the server name of Ip address of your Oracle connection on any (web)site. I could reach your Oracle server (ping and tnsping) so I guess everyone in the world can reach you're server. This could be an security risk to you're data/organisation.
For example:
IP: 147.91.175.146
port: 1521
service_name: orcl
P.S.
This the error that I receive after I use Your tips.
log2.txt
Can I get any help please?
tibor
  • Jan 25, 2018 1:08 PM UTC
Hi @maliodpalube,
Have you tried connecting to SQL*Plus?
Can you verify the Oracle server is still running?
E.g. ping 147.91.175.146
You get an timeout on the connection to Oracle. This looks like the server self is not reachable.
Hi @maliodpalube,
Where can I find SQL Plus? I have SQL Developer and it works in there all the time. I don't know why it doesn't work in FME???
  • Jan 25, 2018 1:44 PM UTC
SQLPlus is command line utility. SQLDeveloper doesn't need an Oracle Client to connect to a database but FME does. Do you have an Oracle DBA to help you configure your environment because you must have everything configured correctly to allow it to work.
Is there any way that I can contact You outside the forum to ask all the problems that I am facing in connection between FME and Oracle DB?
