list flattening
  • Mar 25, 2018 2:29 PM UTC
  • 6 replies
  • 249 views
Hi All,
Just wondering what is the best option to flatten a list on each row to attributes? I know the lists are set at the same size index wise but wondering on the best method
thanks
  • Mar 25, 2018 2:48 PM UTC
Depends on what "to flatten list" means. For example, if the feature has a list called "_list{}" containing these elements, what would be your desired result?
_list{0} = 'a'
_list{1} = 'b'
_list{2} = 'c'
  • Mar 25, 2018 4:46 PM UTC
Hi Takashi,
I would be happy with new attributes against the same parent row i.e. list0 = a, list1 = b and list2 = c.
I was looking at the exposer but thought there must be a simpler approach?
itay
Forum|alt.badge.img+19
  • Mar 25, 2018 6:17 PM UTC
Have a look at the listexploder
danilo_fme
Forum|alt.badge.img+58
  • Mar 25, 2018 6:34 PM UTC
I agree wit you
  • Mar 25, 2018 7:00 PM UTC
I agree wit you
Does this not just create 3 rows - i need them all on the original row?
Thanks
  • Mar 25, 2018 10:00 PM UTC
Hi @lemzip, I think the BulkAttributeRenamer (Regular Expression Replace, Rename mode) can be used effectively here. If you exposed the list elements in the preceding transformer (Right-click on the list name - Expose Elements), the renamed attributes would be exposed automatically.
Text To Find: ^(_list){(\d+)}$  <regular expression that match every element of the list>
String: \1\2  <concatenate the parts matched sub expressions>
