Issue with DB connection: Incorrect syntax near key word 'WHERE'
  • Feb 14, 2014 1:09 PM UTC
  • 105 views
maciej
Hi everybody
I'm pretty new on this community, so please forgive all my mistakes.
I have problem with DB connection. I'm using win xp, FME 2014. I have access to DB, but when i'm  trying to connect with db i recived message as you see on image. All settings in FME and ODBC should be correct. On the other machine (win7) where settings are the same , connection issue doesn't exist. Could you give me some advises where the problem is?
Best regards Maciek
gio
Forum|alt.badge.img+15
  • Feb 14, 2014 3:42 PM UTC
i can't read it well, but do i read where 1=0?
maciej
  • Feb 14, 2014 4:43 PM UTC
Yes, exactly but i don't kow why, because  'WHERE clause:' field is empty.
  • Feb 17, 2014 8:52 AM UTC
I think FME is adding "WHERE 1=0" to read the schema definition without any data. Could very well be expected behavior.
Sounds like a case for Safe support.
David
maciej
  • Feb 17, 2014 11:14 AM UTC
Hi David, Myabe, so now Safe support is working on that.
Thanks
