Is there a way to limit the logging of a long feature attribute value?
  • Oct 12, 2017 12:03 AM UTC
  • 92 views
Hi! I have a HTTPCaller transformer in workspace that downloads 80 MB of data in the same feature attribute before failing. Once it fails, FME desktop attempted to write a feature in the log dispaly and display. The data it tried to display is so big such that the FME desktop crashed. Is there a way to still let it write, but truncate the size of each attribute?
Thank you!
Best answer by david_r
Try the following code in a PythonCaller, modify MAX_LENGTH as needed:
import fmeobjects
MAX_LENGTH = 10
def AttributeLengthTrimmer(feature):
    for attr in feature.getAllAttributeNames():
        value = feature.getAttribute(attr)
        if value:
            feature.setAttribute(attr, str(value)[:MAX_LENGTH])
danilo_fme
Forum|alt.badge.img+58
  • Oct 12, 2017 3:27 AM UTC
Hi @sui_huang,
Could you share your log file to analyze better?
Thanks,
Danilo
  • Oct 12, 2017 7:51 AM UTC
import fmeobjects
MAX_LENGTH = 10
        if value:
  • Oct 12, 2017 5:35 PM UTC
Hi @sui_huang,
Thanks,
Danilo
Hi @danilo_inovacao
unfortunately I cannot upload the log file because the information inside maybe confidential.
The lines before the logging of the huge feature in log file is as following, and they are triggered by the Terminator transformer.
2017-10-12 11:30:59| 13.8| 4.6|FATAL |The below feature caused the translation to be terminated
2017-10-12 11:30:59| 13.8| 0.0|STATS |Storing feature(s) to FME feature store file `C:\\Desktop\\Report_log.ffs'
2017-10-12 11:30:59| 13.8| 0.0|INFORM|+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2017-10-12 11:30:59| 13.8| 0.0|INFORM|Feature Type: `AttributeCreator_OUTPUT'
2017-10-12 11:30:59| 13.8| 0.0|INFORM|Attribute(encoded: utf-16) :.....
  • Oct 12, 2017 5:38 PM UTC
import fmeobjects
MAX_LENGTH = 10
        if value:
Hi @david_r Instead of using Python script, I tried put an AttributeCreator in between and use "Left" string function inside to truncate the attribute. It works. It is the same idea as you proposed but more specific to my situation because I know which attribute is long.
Thank you.
