HTTPCaller - Download PDF and keeping the filename
  • February 27, 2020
  • 131 views
john_esk
I'm using the HTTPCaller to download PDF documents to a set destination folder. The files get saved with the following name structure: "http_download_1582786318570_11140". This is not the same name I get when downloading the documents manually in a browser. I need the documents to be saved with the same name I get when doing it manually. Example: "Askholmen_SE0220343". Is it possible?
Website: https://www.lansstyrelsen.se/sodermanland/natur-och-landsbygd/aktiviteter-och-ingrepp-i-naturen/tillstand-i-natura-2000-omrade.html
(URL to PDF-documents are found under the heading "Bevarandeplaner kommunvis")
HTTPCaller:
warrendev
Forum|alt.badge.img+23
  • February 27, 2020
Using the method @david_r suggested, I have attached an example workspace that will get the filename from the Content-Disposition and write out the pdf file using the filename.
httpcaller_pdf.fmw
2020-02-27-8-23-23
  • February 27, 2020
httpcaller_pdf.fmw
2020-02-27-8-23-23
Nice! :-) Just make sure to remove the _response_body attribute containing the PDF if you need to do any further processing after the AttributeFileWriter.
You can also use the ListSearcher as an alternative to the ListExploder + Tester:
warrendev
  • February 27, 2020
That is probably the better way to go about it using the list searcher.
