How to use PythonEmailer with office 365
  • Feb 10, 2016 10:26 PM UTC
  • 5 replies
  • 178 views
erik_jan
Forum|alt.badge.img+26
I am trying to send an email using the PythonEmailer.
This works fine if I use the smtp.gmail.com server.
But I can not get it to work with the smtp.office365.com server TLS and port 587).
Has anybody got that working.
Any help is appreciated.
This is the error message I am getting:
Python Exception <SMTPException>: SMTP AUTH extension not supported by server.
Error encountered while calling function `email'
f_8(PythonFactory): PythonFactory failed to process feature
Best answer by brianatsafe
Hi @erik_jan,
Can you try switching from TLS to SSL in the transformer parameters? See if that works for you.
Their documentation here: https://support.office.com/en-us/article/Outlook-s...
suggests that some clients refer to implicit TLS as SSL.
brianatsafe
Forum|alt.badge.img+13
  • Feb 11, 2016 6:59 PM UTC
Hi @erik_jan,
erik_jan
  • Feb 11, 2016 7:06 PM UTC
Hi @erik_jan,
Hi Brian,
I have tried all combinations available:
TLS and SSL,
SMTP, POP and IMAP
ports for SMTP (587), IMAP (993) and POP (995)
But no combination worked.
brianatsafe
Hi Brian,
TLS and SSL,
SMTP, POP and IMAP
Hi @erik_jan ,
Perhaps the python code within the transformer could be improved.  Can you try to add the following to the PythonCaller code within the custom transformer:
smtp.ehlo()
smtp.starttls()
smtp.ehlo()
Place it here:
 # Determine how we want to begin the connection
    if (connection_type=='TLS'):
        smtp=smtplib.SMTP(server,port)
        smtp.ehlo()
        smtp.starttls()
        smtp.ehlo()
    else:
Found from: http://stackoverflow.com/questions/64505/sending-mail-from-python-using-smtp
erik_jan
  • Feb 11, 2016 8:24 PM UTC
Hi @erik_jan ,
smtp.ehlo()
smtp.starttls()
smtp.ehlo()
Place it here:
        smtp.ehlo()
        smtp.starttls()
        smtp.ehlo()
    else:
Thanks @BrianAtSafe
That works fine.
Will this be implemented in the FME Store version of the PythonEmailer?
brianatsafe
Hi @erik_jan,
Absolutely, I will make sure we look at implementing this enhancement. I'm glad it worked for you!
