How to do email filtering inside shutdown python script and also exporting the result in sql server DB table?
  • Nov 23, 2018 9:22 PM UTC
  • 6 replies
  • 114 views
Dear everyone, I have an shutdown python scripts which basically sends email to admin after one datadownload has been succeed or failed. My existing py script is as follows:
I now want to impose one "if" condition before email generate, if my user name is "A" and email is "A@nnn.com" then email will not generate.. I have ended my script as follows but it did not work, FME server shows me error.
if nutzer != 'A' AND user_mail != 'A@nnn.com':
smtpserver = smtplib.SMTP(smtpServerAdress,smtpPort)
smtpserver.ehlo()
smtpserver.starttls()
smtpserver.ehlo
smtpserver.sendmail(emailFrom, emailTo, msg.as_string())
smtpserver.close()
Did I have done some mistakes?
And another issue is, I want to also store the result inside sql server DB , how i can write the right script before'send mail?
Thanks
Muqit
  • Nov 23, 2018 10:32 PM UTC
The "and" operator should be lower case, and appropriate indentations are required for the code block within the if statement, as in:
if nutzer != 'A' and user_mail != 'A@nnn.com':
    smtpserver.ehlo()
    smtpserver.ehlo
    smtpserver.close()
    smtpserver.ehlo()
    smtpserver.ehlo
    smtpserver.close()
Thanks a lot.
Cann you please also tell me if I could transfer this results into one sql server DB table?
  • Nov 25, 2018 3:35 PM UTC
Thanks a lot.
I have no experience having connected to an MS SQL Server database with Python script, so cannot help you. It would be better to post a new question specific to the matter.
  • Nov 26, 2018 7:00 AM UTC
Rather than using the shutdown script for this, I would really recommend replacing the workspace writers with FeatureWriters and chain an Emailer and a SQLServer writer to the Summary port.
This way you'll have no Python code to write or maintain.
nielsgerrits
Forum|alt.badge.img+67
This. We use the Emailer transformer a lot in our Server Workspaces.
Thanks david_r for your suggestions. I have successfully connected custom python and third party packages with FME workspace and also fme server and getting all the required results in sql server table.
Kind regards
Muqit
