How to create new dataset of overlapping areas?
epro_admin
Forum|alt.badge.img+7
I have one dataset that has overlapping polygons. I want to advise the data owner of this and ask guidance for what to do when I come across these overlapping areas.
I think the best way to do this is to show them all the overlapping areas. I was able to add on the overlap counts to each polygon (AreaOnAreaOverlayer) which is great, but what I really want is to create a new dataset with the overlapping areas.
I have had a look at the AreaOnAreaOverlayer and Clipper. Is anyone able to provide further guidance or point out if I should be using a different transformer combination?
Best answer by geomancer
Hi, then maybe my wording was poor ;)
I think with the procedure I described you get exactly the areas you need.
geomancer
Forum|alt.badge.img+51
  • August 2, 2023
The AreaOnAreaOverlayer has a parameter Overlap Count Attribute (the default value is _overlaps).
Add a Tester or a TestFilter. When _overlaps > 1 there are overlapping areas at that location.
epro_admin
  • August 2, 2023
Hi @geomancer​ , Thanks for your reply. That was poorly worded on my part. I've attached a screenshot of what I mean. I want to extract into a new layer all the parts that overlap, not polygons that overlap.
Here the green and purple polygons overlap at the pink. The pink is what I want to extract into a new layer. Is there a way to do that through the AreaOnAreaOverlayer and/or does that involve clipping, but I the overlaps reside in one layer not two, and the Clipper requires two a clipper and candidate.
geomancer
  • August 2, 2023
epro_admin
  • August 3, 2023
@geomancer​ Oh gotchya! Thank you.
