How to combine match 2 different attributes to a single attribute
  • Apr 28, 2016 9:01 PM UTC
  • 126 views
I'm new to FME and this should be an easy thing to do. I'm trying to work out the distance of buildings and waterbodies from a structure foundation using the neighbour finder and exporting to Excel. I've been able to work out the distances but I end up with the building distance and waterbody distance on 2 separate rows with 2 identical foundation references as shown below.
I want to be able to combine the 2 distances (Building and Waterbody) onto single line with a single foundation reference like below. How can this be done?
Best answer by erik_jan
The FeatureMerger is the way to go.
Merge both lines on the attribute Foundation Ref.
The Merged output will contain all attributes from both lines.
erik_jan
Forum|alt.badge.img+26
  • Apr 28, 2016 9:07 PM UTC
  • Apr 29, 2016 9:45 AM UTC
Thanks, worked like a charm.
