How do I prevent the Postgres Writer from naming all fields to lower case?
  • April 26, 2023
  • 33 views
kmc5678
When I update the writer and uncheck "Lower Case Attribute Names" under Table Creation it automatically rechecks it after I close the window. I just want to retain the same field name format from the table I'm reading from.
egge
Forum|alt.badge.img+14
  • May 9, 2023
Hi, I think it is some kind of a convention in PostgreSQL to have table names and field/column names in lower case, always. And it looks like the FME PostgreSQL Writer adheres to this convention: "The PostgreSQL writer module stores both geometry and attributes into an PostgreSQL database. Note that attributes are always written as lowercase."
