How can I rename read feature types in dynamic workflows before writing them such that they don't cause the writer to complain about no matching feature types or change the schema from the original feature type?
  • Apr 18, 2017 10:24 PM UTC
  • 139 views
  • Apr 19, 2017 2:12 AM UTC
Hi @asapnet, every feature holds its feature type name as a format attribute called fme_feature_type, and you can overwrite its value with a transformer if necessary.
  • Apr 19, 2017 2:08 PM UTC
@takashi I'm aware of the fme_feature_type attribute, but in my experience, simply changing its content won't transfer the originally-read schema to the new name so that the writer can find it. And I can't use SchemaSetter to fix because it adds ALL attributes to the schema, not just those in the originally-read schema.
jdh
Forum|alt.badge.img+41
  • Apr 19, 2017 2:54 PM UTC
It should be reasonably simple to set the schema to the original feature type and the output to a new name, the trick is to set the schema definition to the original feature type, not the default output name.
  • Apr 19, 2017 5:10 PM UTC
@jdh That did the trick, thanks!
