Get some attribute names with python
  • Feb 15, 2018 9:36 PM UTC
  • 129 views
Hello all,
I have a pythonCaller in my script where I am populating an array with all the attribute names from the feature
test_fields = feature.getAllAttributeNames()
how do I go about excluding any fme generated features (example: fme_feature_type). I can't quite work out the syntax. Any help will be appreciated. Thanks
Best answer by carsonlam
Attributes added by FME usually have a prefix of "fme_", so this is one way to exclude them:
test_fields = filter(lambda name: not name.startswith('fme_'), feature.getAllAttributeNames())
carsonlam
Forum|alt.badge.img+7
  • Feb 15, 2018 9:49 PM UTC
@carsonlam you are a life saver! Thank you so much! That is such a simple solution. I was battling with conditional statements.
  • Feb 16, 2018 8:29 AM UTC
Great answer by Carson. Here's the same thing using list comprehension:
test_fields = [x for x in feature.getAllAttributeNames() if not x.startswith('fme_')]
