GeoMedia/Oracle Format Attributes
  • Oct 9, 2013 3:54 PM UTC
  • 10 replies
  • 62 views
fmelizard
Forum|alt.badge.img+22
I am using FME 2012 SP4 to exposed a number of GeoMedia Format attributes on our text features coming from an Oracle DB i.e. geomedia_text_string, When I run the WB the attribute name changes to oracle_element{0}.geomedia_text_string which looks like a list to me. I have tried to use list manipulators to get to the text string but a list is not exposed.
Any thoughts on how to get to these format attributes so that I can export them?
Cheers
fmelizard
  • Oct 9, 2013 7:12 PM UTC
Have tried exposing the attributes in the reader or via the attribute exposer ?
fmelizard
  • Oct 9, 2013 7:24 PM UTC
Yes I have, but somewhere the exposed attribute name gets modified.
Original exposed Format attribute name = geomedia_text_string
becomes
when I look at it in the visualizer
fmelizard
  • Oct 9, 2013 7:43 PM UTC
Have you tried to make use if the fme_text_string instead ?
fmelizard
  • Oct 9, 2013 7:55 PM UTC
Yes, but  I do not see it in the attribute in the visualizer
fmelizard
  • Oct 9, 2013 8:07 PM UTC
Can you copy the oracle element list into a new attribute?
fmelizard
  • Oct 9, 2013 8:23 PM UTC
None of the List transformers see the list oracle_element so I can't copy that attribute.
fmelizard
  • Oct 9, 2013 8:30 PM UTC
You can try to copy the list element attribute name and paste it into the attribute copier or creator.
fmelizard
  • Oct 9, 2013 8:40 PM UTC
Solution:
1 add all the oracle_element_* attributes in an attribute creator
2 connect the attribute copier  to the attribute creator  to copying the attributes.
3 disable the attribute creator
fmelizard
  • Oct 10, 2013 6:16 AM UTC
With FME 2013 you can replace your solution with a single attribute creator ( it does stay red) but the new attribute is created with the oracle list values.
  • Nov 20, 2013 4:03 PM UTC
GeoCookie ,
I having the same issue.  How do you
How do you specife the value for oracle_element{0}.geomedia_text_string>
Any help is much appreciated.  Tim.
