Generate a list from attributes and back again
  • Jul 23, 2020 8:22 AM UTC
  • 10 replies
  • 678 views
Hi, I could probably work this out over days (weeks!) but I figured asking the question here may be a quicker method to the end goal!
As a first line, I am working in FME(R) 2018.1.0.0 (20180717 - Build 18520 - WIN32) which is unchangeable due to it being what is installed/available at my place of work. Just in case this affects a solution.
Also, this is my first time posting here, so apologies if this is vague/long winded/wrong format etc.
I have a spreadsheet with each row being a project and multiple columns showing the names and addresses of people involved in the project. I have successfully run this through FME to amend the various raw details into the format required to distribute as I require.
However, I now need to generate a duplicate free list of all the 'contact name'/'company name'/'postcode' which I will then be able to reference back to the original format of the spreadsheet (i.e. a row per project with multiple 'contact name'/'company name'/'postcode' columns for each).
The concept of creating a duplicate free list seems simple enough, but I can't think how I would reference back to the original dataset. I'm thinking lists are the answer and have seen there are many 'List...' transformers but I don't really know where to start.
The aim is to pass a duplicate free list (with three columns: contact name/company name/postcode) to a colleague for them to reference against their systems and then to be able to highlight any matches in my original dataset (row per project and multiple columns as above).
I'm thinking I'd need some sort of unique reference number per row/column combination for each, but what about 'contacts' that appear on more than one project and in different columns? Once the list is free of duplicates, can each have more than one unique reference number?
Does this even make sense!
Cheers!
  • Jul 23, 2020 8:34 AM UTC
The format of the original data is sort of like this, except for their being up to 13 sets of contacts and possibly quite a lot of duplication between the various projects and contacts
Project No.
Contact1
Company1
Postcode1
Contact2
Company2
Postcode2
etc.
10000
Bob Jones
Indigo Cleaning
A1 1AA
Simon Wise
Soundsmiths Ltd
YV7 8RD
10001
Sam Tibble
Tibble & Son
SS1 1UB
Shirley Curtin
Intercreate
OK7 6HB
10002
Simon Wise
Soundsmiths Ltd
YV7 8RD
Bob Jones
Indigo Cleaning
A1 1AA
I would like to get a list like below and then be able to easily highlight the matches (against another dataset) by, for example, highlighting the specific match, as well as the Project No. to highlight there is a match on that line somewhere:
Unique Ref
Contact Name
Company Name
Postcode
Bob Jones
Indigo Cleaning
A1 1AA
Simon Wise
Soundsmiths Ltd
YV7 8RD
Sam Tibble
Tibble & Son
SS1 1UB
Shirley Curtin
Intercreate
OK7 6HB
fme-phile
  • Jul 26, 2020 12:02 AM UTC
Hi @_ds Can you upload a spreadsheet showing the original data and the final output. I noticed that when you view on the phone or zoom in on the computer, the first spreadsheet looks different
You know how to´create the list of unique Contacts, right?
So, with the created list the easiest way is to use the aggregator grouping by Contact and creating a list in the project no.
And when you need to reference back to the original list you use a list exploder.
  • Jul 27, 2020 10:09 AM UTC
As requested below by @australia, here is an example spreadsheet of the source dataset (much curtailed vertically and horizontally), as well as the desired edited list. Of course the crux being the ability to reference back to the former. Thanks
FME_forum_example_spreadsheet.xlsx
Done. Cheers!
  • Jul 27, 2020 10:10 AM UTC
Thanks, I'll give this a go
  • Jul 27, 2020 11:51 AM UTC
PS. I'm actually struggling now to create the list of unique contacts! If they were all in one column that'd be ok, but as they are in different columns...stumped!
Have you achieved this? I am lost in this new layout of the forum haha.
But I have simulated your data and achieved it with some manual work. If your data has always the same number of columns it will be hard to create the first flow, but will not be problem after, but if the number are always change, will be more trickier.
I´ve started with a "Cloner", put the number of copies to the number of Collums.
Then you can filter by the field "copynum" and create the unique field contact by simple rename it. So the copynum 0 you rename contact1 to contact, the copynum 1 you rename contact2 to contact and goes through all your data.
Them you can aggregate it by contact (new field) and create list in projectNo field.
davtorgh
Forum|alt.badge.img+12
  • Aug 12, 2020 10:32 AM UTC
HI @_ds​ ,
can you please provide an example spreadsheet of the source dataset? I can't find one in your previous post.
  • Aug 13, 2020 11:19 AM UTC
HI @_ds​ ,
I'm not sure what happened before and why it isn​'t showing, but hopefully it'll work this time.
Thanks, David
