FME Python - Can't find module (ArcPy)
I'm running FME Desktop 64bit and trying to run a Python shutdown script. The script utilizes ArcGIS Pro tools and is written in 3.5.
I get "Python Exception <ImportError>: DLL load failed: The specified module could not be found." I narrowed it down to the arcpy module.
The initial arcpy that comes with ArcGIS Desktop is 32bit, however, Pro comes with arcpy as well and is contained in C:\\Program Files\\ArcGIS\\Pro\\Resources\\ArcPy. This is the one I'm trying to use. My script is below.
import os
import arcpy
print (os.path.abspath(arcpy.__file__))
The above script runs successfully in Sublime and IDLE (ArcGIS Pro), but the error occurs in FME. Here are the things I've tried already:
  • Change the FME interpreter to the same interpreter as Sublime (C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\python35.dll)
  • Change interpreter to Esri ArcGIS Pro 1.4/2.0+Python (3.5+)
  • Copy ArcPy folder from Pro/Resources to C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\arcpy
  • Running the same script in a PythonCreator
  • Running an alternate script substituting "json" for "arcpy". The result being success and showing the location of the json module in C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\json.
So, I know it can see the location, it's just having issues recognizing arcpy. Any help would be greatly appreciated. This job will eventually be published to FME Server once I get it to work on Dekstop.
Hi @jburroughs,
Have you had a chance to check out this troubleshooting article : https://knowledge.safe.com/articles/29799/importing-arcpy-troubleshooting-ideas.html?
One suggestion in this article that I think would be worth investigating is idea #3 : "Add Path appends to your script before importing arcpy". If you haven't had a chance to look at this yet, please consider giving it a read and let us know if one of the steps helps resolve the issue.
Kind Regards,
Annabelle
  • October 5, 2017
annabelleatsafe wrote:
Hi @jburroughs,
Kind Regards,
Annabelle
Hi Annabelle,
Thanks for the link and suggestion! I went ahead and tried multiple appends but unfortunately, was still unsuccessful. Same error.
jburroughs wrote:
Hi Annabelle,
To confirm, when you check your system's PATH environment variable, do you see the ArcPy library you are accessing (C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\python35.dll)? Do you have a PYTHONPATH variable defined? If so, what interpreters are pointed to there?
  • October 5, 2017
Hi @jburroughs,
Kind Regards,
Annabelle
I do have several things in both the system path and PYTHONPATH. See the screenshot below. I tried to cover all bases.
  • October 6, 2017
Also try setting the PYTHONHOME environment variable.
  • October 6, 2017
Thanks for the suggestion, unfortunately that didn't work either.
  • October 24, 2017
I've been working with Safe on this and we've discovered the problem is related to the combination of FME with ArcPro 2.0 with a python script and an SDE reader or writer in the workspace.
