FeatureReader: Google Fusion Table (non spatial): failed to obtain refresh token
  • March 27, 2018
  • 6 views
Using FME2018.0.0.0.0 build 18284 I'm trying to add a FeatureReader connection to a Google Fusion Table (non spatial). I'm able to reach the Google authentication window. However when trying to authenticate I get the following error message within FME.
FME Log:
Can someone help me out finding cause and solution of this error ?
danilo_fme
Forum|alt.badge.img+41
  • March 28, 2018
Hi @gisaalter,
I'm using the same version FME as your and I connected with success in Google Authentication inside transformer FeatureReader:
Did you check the safety rules in your internet?
Thanks,
Danilo
