Dynamic published parameter
  • Nov 28, 2014 3:35 PM UTC
  • 11 replies
  • 160 views
sigtill
Forum|alt.badge.img+25
I have written a script that extracts information from a DB using python. I want this to be a published parameter list. For instance:
FeatureType: Bus, Car
And when run after 10 minutes it might be:
FeatureType: Car, Train
Depending on how this database looks like.
Is it possible to use a scripted parameter for this. Or use a startup python script tp generate a published parameter? If I am correct the STartup pythonscript gets executed BEFORE the published parameters?
  • Nov 28, 2014 3:50 PM UTC
sigtill
  • Nov 28, 2014 3:54 PM UTC
Hi! I found alot of articles - but did not find this. Thanks! I did not like the answer though.. :P And it should also work on FME Server....
  • Nov 28, 2014 3:59 PM UTC
Heisann,
Yeah, not too fond of either solution either, but unfortunately this isn't supported out of the box and as a consequence the solutions are pretty hacky.
There is no way of getting dynamic parameter lists to work on FME Server, as far as I know.
David
sigtill
  • Nov 28, 2014 4:09 PM UTC
I`m thinking a workaround is to run a workspace every minute on FME Server to generate a *.txtfile with the options. And then just let the user know that the dropdown-list is 1 minute old... Or a pythonscript outside of FME generating a *.txtfile as a resource in FME Server that get read on a workspacestartup
  • Nov 28, 2014 4:15 PM UTC
Generating the text file is easy. But how're you going to get it into the list of values for the published parameter?
sigtill
  • Nov 28, 2014 4:20 PM UTC
Hm, thought I had it figured out.... too late on a friday I guess....
sigtill
I guess the pythonscript have to edit the *.fmw - file directly. thats interesting....
  • Nov 28, 2014 4:37 PM UTC
Let me know if you're successful in editing a live .fmw on FME Server! :-)
bjarne
Forum|alt.badge.img+5
  • Nov 28, 2014 6:43 PM UTC
or simply create the html- file on the fly with the dynamic drop down list?
  • Sep 6, 2018 7:34 PM UTC
Has there been any progress on this in FME 2018?
@jimo I'm not aware of this being a feature in FME, this would be best tracked as an idea to show any updates on it. It looks like these are similar: https://knowledge.safe.com/content/idea/27512/dynamic-lookup-parameter.html
https://knowledge.safe.com/content/idea/25358/richer-user-parameters-prompt-ui.html
so it may be worth adding your specific use cases here
