Dynamic Feature Writer Transformer
  • Aug 22, 2019 4:54 PM UTC
  • 7 replies
  • 149 views
I have a feature writer transformer that exports to .csv. For the dataset parameter and CSV File Name I have an attribute "_dirpath" and "_outputName" that are both dynamical created based on the input and the time.
The problem is I want User Attributes to be set to "Automatic" but at the same time there are certain generated attributes that I don't want showing up in the output.
I can use an "Attribute Remover" on most of them with the exception of "_dirpath" and "_outputName" as I need them to tell the feature writer where to write the file to. How do I get out of this catch-22 of having "_dirpath" and "_outputName" available to the feature writer but NOT outputting to the file?
I tried using "VariableSetter" and "VariableRetriever" to assign the attribute to a Private User param but this does not work as I later read that "FME configures user parameters before starting the translation, and their values cannot be changed in the workflow later." Having a global variable also does not work as the "FeatureWriter" won't take it
I could reopen the file after it is written to delete these two extra fields but this very hacky and don't want to do this.
[UPDATE]
I tired putting the feature writer into a custom transformer as mentioned here so that upon creation the attributes show up as params.
This works and I can use the parmas in the feature writer. However, when I use a AttributeRemover to get rid of "_dirpath" and "_outputName" just before passing to the feature writer, it stops working and gives the following error.
test3_FeatureWriter(WriterFactory): MULTI_WRITER: No dataset was specified for MULTI_WRITER_DATASET or test3_FeatureWriter_0_DATASET or CSV2_DATASET
Delete the Attribute Remover and it works again, but with the originally problem of "_dirpath" and "_outputName" being in the output... makes no sense to me
Forum|alt.badge.img+54
  • Aug 22, 2019 5:12 PM UTC
Are the dirpath and outputName derived from the data or just based on an input parameter and the time? If they're not generated from the data you could create a scripted python parameter to generate them.
  • Aug 22, 2019 5:16 PM UTC
dirpath is taken from fme_dataset of the input (The filepath of the input file)
outputName is the input filename with a timestamp appended to it
For Example:
Input: C:\\Temp\\MyFile.csv
Output: C:\\Temp\\MyFile_2019-8-22.csv
  • Aug 22, 2019 5:40 PM UTC
For Example:
Input: C:\Temp\MyFile.csv
Output: C:\Temp\MyFile_2019-8-22.csv
In which case a couple of scripted parameters will do the trick
One for the dirpath
import os
filename = FME_MacroValues['SourceDataset']
path = os.path.dirname(filename)
return path
One for the filename
import os
from datetime import datetime
filename = os.path.splitext(os.path.basename(filename))[0]
now = datetime.now().strftime('%Y-%m-%d')
return filename+'_'+now
  • Aug 22, 2019 6:11 PM UTC
One for the dirpath
import os
return path
import os
Do I use the python caller transformer for these? Or the Python Startup script?
Thank you, I'm done for the day but will try again tomorrow what you said above.
Also I update my question above with another thing I tired. If what you say does not work just going to write the whole thing in python since FME does not seem to play nice
  • Aug 22, 2019 6:21 PM UTC
These are for python scripted parameters, so create a user parameter, choose a type of Scripted (python), give it a name and then paste the code. You'll need to change this line
to reference the name of the parameter of the source dataset
  • Aug 23, 2019 12:03 PM UTC
 I tired that but still running into same problem where if try using the attribute remove it stops working, Thanks anyways
  • Aug 23, 2019 1:51 PM UTC
One you have these as parameters there should be no need to use attributes to set the output filename
