Does a python startup script execute before a python scripted parameter?
  • Oct 22, 2018 1:42 PM UTC
  • 9 replies
  • 122 views
rchoucroun
Forum|alt.badge.img+25
My workspace has a python startup script which calls a REST API and downloads and saves a zipped file geodatabase in zip file called out.zip. The zip file is then unzipped into a Downloads folder. However, because the zip file also contains a folder, and the folder name changes each time (out of my control), I don't know where the final file geodatabase will be located.
For example, when I run the code, the location will be something like this:
...\Downloads\20181018\QSC_Extracted_Data_20181018_103130077000-7024\data.gdb
The next time, the location will be:
..\Downloads\20181019\QSC_Extracted_Data_20181019_111958123000-8024\data.gdb
It's that folder right above the data.gdb which changes.
My workaround was to have a python scripted parameter which searches the date folder (20181019) for a file named data.gdb and return the path. However, it seems that the python scripted paramter is run at run-time prior to the download of the file geodatabase and so, when the translation begins, it can't find it.
Relevant code for the python scripted parameter:
import os
import fme
unzip_dir = os.path.join(fme.macroValues['Download_Path'],fme.macroValues['Today'])
for dirpath, dirnames, filenames in os.walk(unzip_dir):
    if dirpath.endswith('data.gdb'):
        return dirpath
The error I get is:
Unable to connect to the File Geodatabase at '.'. Make sure the correct filename was specified, and that the geodatabase wasn't saved with a newer version of ArcGIS than the one installed locally. The error number from ArcObjects is: '-2147024894'. The error message from ArcObjects is: {}
Best answer by jdh
I believe the order is
  1. Scripted parameters (in the order in which they appear in the Navigator tree)
  2. Startup script
  3. Readers, Creators etc.
The user parameters, including scripted parameters are resolved before the startup scripts are run.
jdh
Forum|alt.badge.img+41
  • Oct 22, 2018 2:02 PM UTC
  2. Startup script
  • Oct 22, 2018 2:08 PM UTC
  2. Startup script
I should've tested before spreading misinformation!
jdh
  • Oct 22, 2018 2:17 PM UTC
Oddly enough, that information is not covered in the otherwise excellent python and fme article. https://knowledge.safe.com/articles/706/python-and-fme-basics.html
@KenAtSafe perhaps the runtime order could be explicitly mentioned in part 1 of the tutorial? Especially since it covers startup scripts before scripted parameters.
  • Oct 22, 2018 2:22 PM UTC
I agree, that would be a very worthwhile addition. @NatalieAtSafe
PS: Ken doesn't work for Safe anymore...
  • Oct 22, 2018 10:15 PM UTC
The order of processes including not only user parameters configuration, startup process also log file opening/closing and shutdown process is very important. I think it should be documented somewhere in the FME official documentations, not only mentioned in an article related to Python scripting.
In my understanding, the order seems to be:
  1. Load workspace
  2. Configure user parameters (including scripted ones)
  3. Open log file
  4. Startup process (Which one does run first - Tcl or Python?)
  5. Perform translation
  6. Close log file
  7. Shutdown process (Which one does run first - Tcl or Python?)
jdh
  • Oct 22, 2018 10:30 PM UTC
  1. Load workspace
  3. Open log file
  6. Close log file
There's also a slight discrepancy in order of processing of input/close methods with multiple PythonCreators.
If there is a reader present, the order is
PythonCreator_1 Input
PythonCreator_2 Input
Readers
PythonCreator_1 Close
PythonCreator_2 Close
which is as per the documentation.
If there is no Reader, then the order is
which if you were expecting the same order as the first case, could cause issues.
Not that I can think of a scenario where I would be mixing Input and Close methods without a reader present, but I am strongly in favour of documenting behaviour regardless.
rchoucroun
  • Oct 23, 2018 12:01 AM UTC
  2. Startup script
Thanks @jdh. This is what I suspected. In the end, I just edited my startup script to move my geodatabase to the location that the parameter is looking.
fmelizard
Forum|alt.badge.img+22
  • Oct 23, 2018 6:23 PM UTC
Readers
I see and I believe. Good detective work.
jdh
  • Oct 23, 2018 6:29 PM UTC
I'm in the process of creating a training module for python scripting in FME. Writing the materials has caused me to challenge a bunch of my habits (ex FME macro values), go through the documentation materials with a magnifying glass and test a whole lot of what if scenarios.
