Creating multiple MapNikRasterizer Maps using overlapping polygons
  • Jan 19, 2021 2:22 AM UTC
  • 89 views
kieranmg
Forum|alt.badge.img+3
Hi All,
I'm trying to create a series of basic maps to illustrate address points which are broken into clusters. The cluster size range from 16 to 600, some clusters are beside each other in built-up-areas.
When processing each cluster it seems the extent(or boundbox) of each map clips layer data in overlapping areas. Can anyone suggest what i may be doing wrong? or another approach.
Many thanks
Kieranmapnikrasterizer1mapnikrasterizer2
gio
Forum|alt.badge.img+15
  • Jan 19, 2021 10:11 AM UTC
@kieranmg​
If you want ot process data in overlapping area's you can spatial relate the area's first.
Then clone the area's which overlap 1 or more times.
Then you can do your processing grouped by area_ID and _copynum (attribute from cloner)
kieranmg
  • Jan 20, 2021 2:34 AM UTC
@kieranmg​
Thanks gio, i've attempted this but i'm not sure it will work. The overlapping data will have a _copynum value of 1,2.. etc but each internal non-overlapping part will always be 0, so the group by won't work. hope that makes sense
gio
  • Jan 20, 2021 9:40 AM UTC
@kieranmg​
I wrote :
Group By on area_ID and _copynum.
Either concatenate them or use both attributes in the group by.
Latter is not always available on all transformers.
If you don't have an unique area id make one using a counter.
So group by is possible, in fact i do it all the time.
Also this question has been posted in various forms.
I would advice to use t he search function in this forum. Often this question is in relation to clippers, overlayers.
It always helps to post a sample data set, you get sample solutions pretty quick on this forum.
Greets,
Gio
kieranmg
  • Jan 21, 2021 10:54 PM UTC
Thanks Gio, sorry i meant to include that this was using both area_id & copy_num.. The bit i was overlooking was the 'Generating List' parameter in the SpatialRelator so i could use ListExploder to get the other areas rather than clone. Thanks for sending me on the right path
