Can I modify the number of characters in user attribute name length for a writer?
  • Jan 29, 2016 8:52 AM UTC
  • 5 replies
  • 371 views
Hello.
I'm working on FME workbench 2014. I stumbled upon an issue when creating a writer. It seems like I can't put in a name of an user attribute that has more than 10 characters. If I put in a longer name, FME automatically reduces it to 10. Is there a way to fix this?
Regards,
Bjorn M
Best answer by davideagle
When you get issues like this always refer to the FME Readers and Writers Reference manual as it often will describe these types of format limitations:
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/Format-List-All.htm
In this case @takashi has I'm sure got it spot on, that you are trying to work with the Shape format?
  • Jan 29, 2016 9:48 AM UTC
If the destination format is Esri Shape, maximum length of attribute name is restricted to 10 bytes by the format specification, FME just follows the restriction.
davideagle
Forum|alt.badge.img+21
  • Jan 29, 2016 10:07 AM UTC
  • Jan 29, 2016 11:15 AM UTC
Thanks for your answers.
You are correct, I am working with tha Shape format. Forgot to include that.
I wasn't aware of this restriction, so thanks for pointing that out.
Is there any way in FME to expand the field name length?
jovitaatsafe
Forum|alt.badge.img+11
Hi @ainelojaan,
unfortunately as Takashi has said, the 10byte limit is due to the esri shapefile format structure, so in order for us to write out a correct shapefile, it has to follow those specifications. If you're looking for a workaround to write longer field names, the file geodatabase format may be a good alternative, and it also allows for field aliases unlike the shapefile.
If you have any further questions on it, please feel free to post a new question, as I worry this old thread from a few years ago may be easily overlooked. Thanks!
