batch run with dynamic schema does not bring results
  • Oct 9, 2013 5:59 AM UTC
  • 60 views
Hello,
I have a workspace, where I read data from a non-spatial and a spatial database. I write the data to a dynamic schema into an Esri file geodatabase.
The workspace runs fine, when I start it with FME, but it doesn't write any data to the geodatabase,  if i call the same workspace with a batch file.
What can be the problem?
Thank you for your help.
Isabell
fmelizard
Forum|alt.badge.img+22
  • Oct 9, 2013 6:21 AM UTC
Hi Isabell,
Since the batch only calls the ws, the only issue I can think about is that there is no ESRI license available when running the batch.
  • Oct 9, 2013 7:26 AM UTC
Hi Isabell
It's difficult to specify the problem based on only the information you posted. First of all, see the log file. There could be a hint about what happened, or what did not happen.
Takashi
Hi Isabell,
it sounds like a behavior we went into a couple of weeks ago. Without knowing your data and log. My guess is, that this is a known issue in relation with ArcGIS 10.0 or 10.1. When you call your batch file (maybe as scheduled task) it is not possible to get a Ersri license from the license server.
In ArcGIS 10.2 this is should be fixed. Or you give the the File Geodatabase API a try, because this writer does not use ArcObjects. You just need to be aware that not all File GDB funcitonality is available.
Best regards,
Stefan
  • Oct 9, 2013 10:47 AM UTC
Hello Stefan,
I had a closer look at the logfiles and indeed in the batch run logfile, there isn't a checkout of an Esri license.
But we already use ArcGIS 10.2, so it seems the problem still exists.
Maybe I can use a workspace runner to avoid that problem.
Regards,
Isabell
