Add an attribute to geometry
  • Apr 1, 2024 8:49 PM UTC
  • 93 views
jp12212
Forum|alt.badge.img+4
Hi!
I want to add an attribute to geometry - is this done with the geometrypropertysetter?
For instance, add ‘water  asset’ to a cylinder but not as a layer name rather as an data tag / table.
I ultimately want to be able to bulk add them however am starting with a simple test case.
Thanks.
hkingsbury
Forum|alt.badge.img+73
  • Apr 2, 2024 12:47 AM UTC
AttributeCreator or AttributeManager will allow you to create a new field/attribute
