Trouble connecting to Esri ArcGIS Server Feature Service
  • Aug 31, 2017 3:30 AM UTC
  • 7 replies
  • 141 views
gisgeek
Forum|alt.badge.img+9
Hi I have workbenches saved where I connected to Esri ArcGIS Server Feature Service however now they don't work and they used to. I suspect it is a proxy issue which is stopping me connecting but this is an existing link that no longer works for me. https://maps.npdc.govt.nz/arcgis/rest/services/viewer/utilities/MapServer.
This is what I get in the log:
he 'ARCGISFEATURES' reader was destroyed successfully
'ARCGISFEATURES' reader was created successfully
Creating reader for format: Esri ArcGIS Server Feature Service
Trying to find a PYTHON plugin for reader named `ARCGISFEATURES'
Loaded Python module `arcgisonlinefeatures' from file `C:\\Program Files\\FME\\plugins/python27\\arcgisonlinefeatures\\__init__.pyc'
Python Exception <TypeError>: unsupported operand type(s) for +: 'NoneType' and 'unicode'
Could not create Python Reader `ARCGISFEATURES'
Failed to open the dataset 'https://maps.npdc.govt.nz/arcgis/rest/services/viewer/utilities/MapServer'
DATASET INFO:
DATASET: https://maps.npdc.govt.nz/arcgis/rest/services/viewer/utilities/MapServer
NUMBER OF PARAMETERS: 7
RETRIEVE_ALL_TABLE_NAMES = Yes
AUTH_TYPE = None
USER =
PASSWORD = ********
TOKEN =
_MERGE_SCHEMAS = YES
RETRIEVE_ALL_TABLE_NAMES = YES
The 'ARCGISFEATURES' reader was destroyed successfully
trentatsafe
Forum|alt.badge.img+7
Hello @gisgeek,
Which version of FME are you currently using? Is your proxy set up correctly?
I see a previous issue that caused a custom proxy map definition set to no proxy that would cause the following error:
| Python Exception : unsupported operand type(s) for +: 'NoneType' and 'unicode' |
This has been fixed in 2017.1. If you are not using 2017.1 currently, may I ask you to try installing 2017.1 to see if that addresses the issue. The 2017.1 installer can be found here : https://www.safe.com/support/support-resources/fme-downloads/
gisgeek
  • Sep 4, 2017 4:21 AM UTC
I installed 2017.1 but it hasn't made any difference to being able to connect. I get this error:
Python Exception <ImportError>: No module named parser
DATASET INFO:
AUTH_TYPE = None
USER =
PASSWORD = ********
TOKEN =
I think it is something to do with my proxy set up up but I don't know what. I have tried connected to wfs services and they work ok Web Feature Services are giving me grief. This is a workbench I have had running in the past but now it doesn't connect so something has changed?
trentatsafe
Hello @gisgeek
If you follow instructions in the Top answer found here: https://knowledge.safe.com/questions/44922/getting-the-error-python-exception-no-module-named.html
In short, try deleting the following files:
fme\\python\\js2py\\translators\\pyjsparser.pyc
fme\\python\\js2py\\translators\\pyjsparserdata.pyc
fme\\python\\js2py\\translators\\std_nodes.pyc
These are the old .pyc files from the older FME installs.
This should resolve the issue. Please let me know.
gisgeek
  • Sep 5, 2017 9:48 PM UTC
Hello @gisgeek
Thanks. I tried doing this yesterday and it didn't fix the problem.I also uninstalled and reinstalled it also but this made no difference. I have installed a clean build on another machine and it works. This is good but this makes me reluctant to upgrade in future because I might get similar problems.
trentatsafe
hello @gisgeek
These upgrade problems are always tricky and discouraging for users when applying newer updates. One thing I would suggest which has possibly assisted in not experiencing issues when upgrading FME Desktop, is for each install, have it installed into a new directory, this will prevent any 'cross-contamination' so to speak of installs.
For example:
Upgrading from 2017.0 to 2017.1 using the following directories
C:\\Apps\\FME 2017 - 64bit - B17291
C:\\Apps\\FME 2017.1 - 64bit - B17539
  • Feb 26, 2018 4:12 PM UTC
I have a model using a FeatureReader with ARCGISFEATURES type on FME Desktop Win64 2017.1.0.0 and it works well.
Then moving the model to another server with 2017.0.1.0, the Featurereader seems to work, but never read more than one Query, so only results for the first query of the WHERE was fetched.
When installing FME Desktop Win64 2017.1.2.1 I am not able to initiate the FeatureReader with
ARCGISFEATURES
at all.
2018-02-23 22:25:56| 6.1| 0.0|INFORM|Creating reader for format: Esri ArcGIS Server Feature Service
2018-02-23 22:25:56| 6.1| 0.0|INFORM|Trying to find a PYTHON plugin for reader named `ARCGISFEATURES'
2018-02-23 22:25:56| 6.1| 0.0|INFORM|Using Python interpreter from `C:\\Program Files\\FME\\fmepython27\\python27.dll' with PYTHONHOME `C:\\Program Files\\FME\\fmepython27'
2018-02-23 22:25:56| 6.1| 0.0|INFORM|Python version 2.7 loaded successfully
2018-02-23 22:25:56| 6.2| 0.1|INFORM|Loaded Python module `arcgisonlinefeatures' from file `C:\\Program Files\\FME\\plugins/python27\\arcgisonlinefeatures\\__init__.pyc'
2018-02-23 22:25:57| 6.8| 0.6|ERROR |Python Exception <ImportError>: No module named parser
2018-02-23 22:25:57| 6.8| 0.0|ERROR |Could not create Python Reader `ARCGISFEATURES'
2018-02-23 22:25:57| 6.8| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
Anybody got some ideas?
trentatsafe
ARCGISFEATURES
at all.
Hi @aalppa
Have you tried the suggestion in the below comment?
Does that solve the issue?
