There is a fault "Installing FME Desktop from the Windows Command Prompt" documentation
  • Jan 28, 2020 5:28 PM UTC
  • 51 views
Hello,
While configuring a license from the command line, I found this article.
Only, I couldn't get it to work.
The problem is, that you have to use fmelicensingassistant_cmd.exe in all cases.
(Not just fmelicensingassistant)
Could you please update your documentation accordingly?
And maybe explain that you can retreive the license type bij running the --query command line.
Kind regards,
Fabian Hofman
Axians
fmelizard
Forum|alt.badge.img+22
  • Jan 28, 2020 10:09 PM UTC
Hi @fabian I can use fmelicensingassistant.exe from the command line as the doc says. Please send more details about your problem to https://www.safe.com/support/report-a-problem/ Thanks!
