FME Server public URL ?
jhawks
Forum|alt.badge.img+7
After much confusion we have a public 2013 fme server!:
https://fmeserver.ncd.noaa.gov/fmeserver/login/end
It looks like in 2013 version the admin interface and the public interface have been combined? Wha's the public url for workbench so users dont have to login?
mark2atsafe
Forum|alt.badge.img+48
  • April 19, 2013
You're correct that the two interfaces have been combined. There's just one login now and what you can see/do depends on your permissions. Really that was all the difference between interfaces was anyway.
I'm not sure what you mean by the "public url for workbench". If you want to let outside folk run a translation you just need the same url as before. Again, it will be down to the permissions on the system whether any particular workspace can be run by anyone or needs an account to do so.
Hope this helps
Mark
  • April 21, 2013
Congrats!
Assuming you've turned on security, users will always need to log in in order to access FME Server.
To bypass this for public users, you could similutate a auto-login by:
  1. I believe you should still be able to set up the FME Server web interface to have a default username and password saved so that the public can access it.
  2. Alternatively you could pass users to the REST API and just have a standard REST token you give out. Both of these options require you to have some user (such as the guest account) that is logged in by the users be default.
If you're referring to users being able to access FME Server via FME Desktop, they will indeed always have to log in as a user. Perha[s create a "public" user with a password of public and  setup the access rights to such a user.
jhawks
  • April 22, 2013
Okay I'm getting there. I have a public web form now.
http://ocs-gis.ncd.noaa.gov/fme/fme_test.html
However my published workbench has a drop down for menu for 5 different output format (from published parameters). I want the same thing on the web form. Also a checkboxes for each of the layers. Should I just do this in html ?
mark2atsafe
  • April 22, 2013
Take a look in the FME Server interface. You're looking for a button marked Show Developer Info....
When you click on that then the code you need to show the published parameters will be displayed. Hopefully this will help when you are creating a front end for the system:
jhawks
  • April 22, 2013
I did that, thats where I got the code for the web form. However my published workbench has the drop down for the formats but the web form doesn't
