Emailer fails with SSL exception
lifalin2016
Forum|alt.badge.img+30
Hi all.
Our IT department has recently moved our mail system to Office365, and so all the emails sent from FME must now use a new endpoint and credentials.
I've tried to run a super simple workspace, and it fails: Emailer_Søgeord: <class 'ssl.SSLError'>: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
Our previous setup didn't use SSL, but the new one does. But apparently FME cannot handle it ?
The only items changed are: host, port, encryption (from None to SSL), and sender's username and password.
Using FME 2020.0 and Python 3.7+, and I have upgraded the Emailer transformer from 2017 to the latest.
Please advice. Cheers.
Best answer by lifalin2016
Ok. my digging did uncover the cause. It is indeed the encryption, that now has to be TLS, not SSL.
It seems that this was changed in Python 3.5, and since 2020.0 doesn't support any older versions (except for 2.7 if installed), TLS is the new default.
My last obstacle was my weary butter fingers, that misspelled "relay" as "reply" in the credentials setup. After that was corrected, the email was sent correctly.
  • April 14, 2020
It may be a long shot, but have you tried different ways of entering the mail server hostname, trying both with and without the https prefix in the Emailer:
smtp.office365.com
https://smtp.office365.com
Of course you'll have to use the proper hostnames, the above are just examples.
lifalin2016
  • April 14, 2020
smtp.office365.com
Isn't https and SSL synonymous ?
Besides, the error message talks about a version number issue, not a protocol issue.
  • April 14, 2020
To a human, yes :-)
lifalin2016
  • April 14, 2020
I've googled the error message, and it seems it might have to do with the protocol version having changed from PROTOCOL_SSLv3 to PROTOCOL_TLS in Python 3.5.
I tried to change the encryption in the Emailer to TLS (instead of SSL), but that only gave me another error:
SMTPDataError: Could not complete request. Message: (554, b'5.2.0 STOREDRV.Submission.Exception:SendAsDeniedException.MapiExceptionSendAsDenied; Failed to process message due to a permanent exception with message Cannot submit message. 0.35250:5B2C0000, .... [Hostname=VI1P190MB0542.EURP190.PROD.OUTLOOK.COM]')
Digging deeper.
lifalin2016
  • April 14, 2020
