anyone had success running a workspace that has arcpy code with FME Server 2018 ( 64 bit) and ArcGIS Server( 64 bit)?
  • December 19, 2019
  • 6 views
I'm seeing the 'unable ot load interpreter' issues when publishing FME workspaces (with arcpy) to FME Server. They run fine in my local with the python interpreter pointing ot the python libraries from ArcPro install but fails on server.
mygis
Forum|alt.badge.img+13
  • December 26, 2019
If not mistaken you will need to have ArcGIS Desktop installed on the Server.
