xfmap help
  • April 5, 2013
  • 5 replies
  • 86 views
jdh
Forum|alt.badge.img+41
hi all,
I need to use the XMLFeatureMapper in a script, and I want to exclude nodes that contain a specific selfclosed tag.
if the xmls is
<feature>
<ID>1</ID>
</feature>
<feature>
<ID>2</ID>
<at1 name="a"/>
</feature>
<feature>
<ID>3</ID>
</feature>
I want to read in only feature 1 and 3, excluding all features with tag <at1 />.
I'm really not familiar with xfmap, but managed to get the following to read in all features:
<xfMap> <feature-map> <mapping match=feature">     <feature-type> <literal expr="feature"/> </feature-type>              <attributes> <attribute>                     <name>  <literal expr="ID"/> </name> <value> <extract expr="./ID"/>  </value> </attribute> <attribute>                     <name>  <literal expr="attribute1"/> </name> <value> <extract expr="./at1[@name]"/>  </value> </attribute> </attributes> </mapping> </feature-map>    </xfMap>
But i really want something to exclude the feature if it contains the tag, something like <mapping match="feature" except ="feature.at1"> but that is not the right syntax.
help?
fmelizard
Forum|alt.badge.img+22
  • April 5, 2013
I would try to filter out the nodes before creating features,
 that can be done with the xml fragmenter set to exclude or testing the fragments (tester/testfilter).
 Hope this helps.
  • April 6, 2013
xfmaps can be hard to write. If you're using FME 2012 or newer, I strongly recommend to replace them with XML feature paths instead, they are a lot easier to work with.
Have a look at the following FMEpedia article on XML feature paths, it gives a lot of good info in how to get started.
For your example, I would just use a feature path on "feature" and then filter out the unwanted features using a Tester or something like that to isolate those with a particular attribute present.
David
fmelizard
  • April 8, 2013
I agree with David, feature paths are a lot easier, see this short video, to get an idea how it works.
In your case after reading you can filter out the unnecessary nodes.
jdh
  • April 8, 2013
So there were a couple of complications not mentioned, specifically I don't know what the xml path will be until I start processing another dataset, which will trigger the xml reading.  That leaves out anything involving an xml reader or FeatureReader transformer.
Also I don't actually know what the name/value pair in the self closing tag will be.  ie  <at1 name="a"/> i know that it will be <at1 something="something else"  optional="something optional" />
I did try the xml fragmenter instead of the xml feature mapper, but I couldn't  get the exclude to work properly.  It would excluded the attribute, but not the feature.  The xmlfragmenter also required that I manually expose the attributes I was interested in, and had a slightly  higher overhead in that it pulled in all the attributes from the xml file, not just the few I was interested in.  Going into the advanced flattening options seems just as complicated as producing an xfmap.
  • April 8, 2013
Hi again,
have you looked at the XMLFlattener?
David
