Workspace Runner - space in file path
lukas108
Forum|alt.badge.img+7
Hi. I run the workspace runner with the file path in user parameter. If there is a space (“ “) in the path, the parameter is loaded in a weird way: --DestDataset_ACAD {${=I:<backslash>Data<backslash>CAH<backslash>GAK<backslash>Data<backslash>GAK<backslash>FME-WorkSpace<backslash>09-Export<space>ZML<solidus>_final…
But it works fine if I run original workspace. Is there some bug with Workspace runner?
Forum|alt.badge.img+49
Just for clarification, does it run ok with WorkspaceRunner like that?
lukas108
  • February 13, 2024
Result in always... ACAD writer: An error has occurred
That’s not much to go on, is there anything else in the log perhaps?
lukas108
  • February 13, 2024
But I have many Workspace runners in the workspace and each has ACAD writer with same path. I think the error occurs only with the workspace that I edited in the new FME version. But I did nothing with the file path.
