Workpace statistics
  • Jan 24, 2013 4:16 PM UTC
  • 5 replies
  • 97 views
johann
Participant
Hello,
is there a way to know some stats about a workspace, such as the number of transformers used (including customs), the number of feature type, etc...
My workspace is quite huge... I can't count manually...
Thanks,
Johann
sigtill
Forum|alt.badge.img+25
  • Jan 24, 2013 4:52 PM UTC
Reading the *.fmw with FME (using a TEXT READER) and counting for instance TRANSFORMER occurences or something? Nothing within the FME environment AFAIK.
davideagle
Forum|alt.badge.img+21
  • Jan 24, 2013 5:48 PM UTC
Hi Johann - Interestingly I was convinced that in Windows tootips you'd get back exactly what you are looking for. I knew I had seen and used it before but in Windows7 the tooltip doesn't show, so perhaps it's a setting in the OS somewhere. However, I have a WinXP VM and just as I had remembered, you just hover your cursor over the file and...
johann
Participant
  • Participant
  • Jan 25, 2013 9:02 AM UTC
Thanks ! It worked.
With WinXP, the number of transformer is displayed in tooltip : 1540 transformers !
I had the same result editing the fmw file, counting occurences of "XFORMER_NAME".
sigtill
  • Jan 26, 2013 2:19 AM UTC
Wow 1SpatialDave, very usefull!
fmelizard
Forum|alt.badge.img+22
  • Feb 13, 2013 10:54 PM UTC
Yes, long ago we did a shell extension for Windows XP that showed a bunch of metadata about a workspace. I think you could see the information in the windows explorer table view by exposing more columns as well.
Sadly, the interfaces we used went away with WIndows 7.  I realize this is useful so we'll look at bringing it back.
Or maybe we should just make a .fmw READER for FME that would tell us things like this :-)
