When will the FME Projections for GDA2020 be fixed in FME Form and FME Flow?
  • Jan 4, 2024 11:51 PM UTC
  • 6 replies
  • 191 views
cory
Forum|alt.badge.img+7
Hi Team,
I was wondering if there was an ETA as to when a permanent solution for fixing FME Form (and Flow) will be available, as we're still experiencing issues with reprojecting data in GDA 2020.
The work around at the moment that we have been given is;
-	Open up the following file in Notepad (open as administrator) :
"C:\Program Files\FME\Reproject\CsmapTransformationExceptions\TransformationExceptions.db"
- Find the Australia section and add the following line :
GDA2020-7P|GDA2020|XFORM|FWD|NULL_FME
- Save!
Cheers
milo89
Forum|alt.badge.img+27
  • Jan 5, 2024 4:09 AM UTC
Hi @cory​
I've been dealing with data in (to and from) GDA2020 but haven't really experienced any issues. What version of Flow/Form are you using? That said, the accuracy of some of those datasets wouldn't really require transformation.
Does your data require conformal and distortion transformation?
Interested to hear more as I'm constantly waiting for GDA2020 to through spanners at some point.
cory
  • Jan 5, 2024 4:22 AM UTC
Hi @cory​
hi @milo89​
We're downloading data from SLIP (State Government Authority Portal for WA) and the data is natively presented at EPSG:7844 - GDA 2020 LL.
We found this issue in 2023.1 and 2023.2.
A colleague of mine at another LGA has also experienced the issue (and was the one who first alerted us to the issue).
I'm currently running 2023.2 Form and will be upgrading Flow next week.
It appears that the data is being reprojected approx 1.8m again, so it looks like it's doing a double reprojection using CsmapReprojector.
milo89
  • Jan 5, 2024 4:50 AM UTC
Hi @cory​
I'm currently running 2022.2 but I must admit I haven't dealt with much data provided in GDA2020 LL.
I've experienced a similar issue when data was incorrectly provided as GDA2020-MGA54. I believe the reader via the navigator was reprojecting as well as the CsmapReprojector.
Is the source data in the right location when viewing in inspector? Are you setting the coordinate system or reading from file?
cory
  • Jan 5, 2024 5:06 AM UTC
Even with the CRS set in FME Form on the Reader and Writers, without the fix, the reprojection of data shows as this;
Black is the known good data.
Red is the data being downloaded, without the fix:
CadDifference
The only way we know about this fix, was it was SAFE Support that advised one of my colleagues on how to fix it.
I'm just hoping to get the fix put into FME Flow/Form so that I don't have to manually update it :)
milo89
  • Jan 5, 2024 5:13 AM UTC
Thanks. That's one to keep an eye on for sure.
df_cos
Forum|alt.badge.img+17
  • May 20, 2025 7:17 AM UTC
Discovered today that this issue has been resolved from 2024.1 onwards.  That is for Form - not sure if fixed in Flow as well, but I assume so.  Haven’t done any testing to check, but if anyone does in the meantime and can confirm in here that would be appreciated.
On the changelog page at Changelog - FME by Safe Software
Good to know it’s been sorted :-)
