What is the simplest way to create polygons from the extents of a LAZ file?
  • Mar 1, 2018 2:11 PM UTC
  • 63 views
I have 1000 LAZ files and need to create a grid of the extents including the file name attribute. What would be the easiest method do carry this out?
debbiatsafe
Forum|alt.badge.img+24
Hi @robertdbuckley
You could add a LAS reader as a Single Merged Feature Type. Add a BoundingBoxReplacer and an AttributeManager. The fme_basename attribute will be the name of your file. Rename your attribute if you wish.
Hope this helps,
Debbi
